To drill or not to drill?
Getting ready to install my Comp cam this weekend, here is my question. Some of the install directions that I have read say to drill out the hole on the throttle plate. Is this something that is a must? How many have drilled theirs out? Please give some feed back on this if you would. Thanks.
From what I have read both here and at www.ls1tech.com, it depends on how big the cam is. There are other alternatives to drilling: you can adjust the throttle stop screw, or get the PCM retuned to raise the idle. Personally, I would use drilling as a last resort.
DO NOT DRILL IT! The PCM will learn and compensate for the hole. Get a tune sometime, that is the only way to fix a surging idle problem if it exists. If worse comes to worse open the throttle cracker just a bit.
The Comp Cam is #54-412-11 212/218 522/529 114LSA. Have no special tune on at this time, would like to go with a Westers after cam is installed and driven to see what improvement it makes. Any helpfull tips would be accepted here. Thanks.
with that cam you might not need hardly any tuning. you might need to idle her up a bit. are you going to do springs? i would do at least the z06 springs. nelson does a mean tune on that cam also.
I will be replacing the stock push rods with chrome moly rods and will also be installing LS6 valve springs. Waiting on the springs, hope they make it here by Friday. Still having trouble finding a valve spring compressor in time to do the job. May have to fabricate one to get the tuff ones done. Hoping that this cam will wake it up some, and then will order a Westers module.
It will man. I have the same cam. Make sure you get some hardened 7.4" rods.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 294 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
