Old iPod...
Gordeez
Is there anyway I can get my iPod
to play in my Car of off the Radio Stations?
Its one of the older iPods, from when they first
came out. Theres no Dock. I have a 94 Z-71.
belkin makes a fm transmitter for ipod. there are other manufactures that make fm transmitter for ipod, but belkin is the one i've seen almost everywhere that sells ipod.
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
