Cheap lift???
Waaaaaaaaaayyyyyyyyyyy too much $$. Just buy the "Ford" keys. Do a search here on the board. about $30 ea. I think. It basically has a different index than your stock torsion bar keys. You can turn them up without getting all the negative side effects like a stiff ride. I'd just turn your stock keys up, no more than about an inch, probably will ride the same. If you want to go up to 1.5 or 2" the new keys might be a better idea. just use the search feature, you'll find tons of info. Chris
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 906 Guests (See full list)
