I have started to hear the fuel pump make much more noise than it used to. Just a louder hum before it stops. I am thinking it is starting to go. Anyone disagree or even agree with me. Please give me your thoughts. If so, how hard are they to change? :thumbs:
Pickup? Easy to change. Get a couple buddies to come over, supply some cold beverages for them (after of course) and ask them to help lift the bed off, once it's un-bolted and the wire harnesses disconnected.
Then just swap the pump and ask for help putting the bed back on.
It's getting louder. When was the last fuel filter change? I like to do it every year, it's cheap insurance to help prevent the pump from having to push too hard...
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,017 Guests (See full list)
