Climate Controls
I am having a problem with my temperature control on my 2000 GMC Sierra. After the truck has been running for a while and the interior heats up the temperature it will not go back to cool. When I turn the temperature control knob to cool it just stays hot. This only occurs after the truck has gotten warm. It may eventually get cool or it may just stay hot until the truck is shutoff and cools down.
My local dealership told me (without them actually looking at the truck) that I probably needed a new dashboard climate control assembly. Is there anyway to confirm I need to replace the dash controls? If there is a problem with the controls can the control box be fixed?
Has anyone else seen this problem?
I had the same problem with my 99. It is not the control module. The dealership made that stupid assumption with me. You will find out in this forum that the NBS pickups have had quite a few Damper Motor failures. Have them replace that first. I can almost guarantee you thats the problem.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,017 Guests (See full list)
