Procomp Shocks
Does anyone know if the ES3000 are all rated for 0-3" lift? I have read other posts that they are, but not sure if it is a seperate shock or if they all are.
Also, I am going to put the ford keys on tommorrow on my 02 silverado z71 and get an alignment. I ran accross a post in another forum that says to loosen the tie-rod ends to make sure they are not in a bind. Is this a possible problem? After I put longer shocks on is there anything else I should look into adjusting/replacing?
Thanks
You have to get the right part numbers on the ProComps for them to work with 0 to 3 inches of travel. I put them in my post when I put the shocks on...Give me a bit, and I'll post them here too.
As for other adjustments, I didn't make any, and I wouldn't touch the tie rods...Period.
**Edit**
Go here for my post. Complete with part numbers.
Yes they are listed for 0-3 inches of lift the part numbers are Front EXP-ES314580, the rears are EXP-ES325509. they are 31.95 each. Thoese are Summit racings part number. they put a prefix infront of the factory number. Keep in mind they do not include boots you need to buy the seperatly they are only a few bucks,
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,006 Guests (See full list)
