My truck failed emissions it threw code p1133 can anyone tell me what thet is? This a 96 S10 4.3.
Well, code P1133 is an O2 sensor error and should turn on the CEL (Check Engine Light). The actual description under the OBDII listing is: "Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1 (Rear Bank)".
Since the engine is north/south and not tranverse, it should be th passenger side sensor which has the problem. This could also be a shorted wire or corroded connector at the sensor and not necessarily the sensor. You'll want to check the harness and connectors first, before replacing the sensor.
Ray
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,017 Guests (See full list)
