vin number and factory specs list
2002sierraz71
No, but there is if you look up the RPO codes on the sticker in the glove box and compare it to the RPO list link on the left side of this site.
If you have a friendly contact at the dealership, they can print a LOT of information about your vehicle from the VIN. The RPO codes also provide a sure-fire method, as was suggested.
When I was considering the purchase of my truck (I live in NC, truck was in Omaha, NV), a service manager at the local dealership input the VIN and printed out all the RPOs/features, the build facilities, recalls performed/needed and maybe some other stuff.
As hard as it might be to believe, he also add a Car-Fax run which I greatly appreciated!
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 788 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
