Day Time Running Lights
My company work trucks DRL's stopped working and I can't find the controlling relay for the lights. Fuses are all good and everything else works, can anybody tell me the location of the relay? Thanks, Roger P.
It is in the underhood relay box, but it is also controlled by the BCM module. There could be more too it. There are two fuses that run to the relay both are 10amp and one is for the ignition.
Peter, I have 5 relays in the box under the hood, none are labeled for the DRL's, the relays are, starter,brake, a/c, fuel and horn. The rest are fuses and the fuse for the DRL's is located in the fuse box inside the cab/ drivers side dash next to door. # 15 is labeled DRL-FOG, the indicator on the dash is on for the DRL's, the high and low beams come on,but the low beams go off when the high are turned on, so I'm thinking the outside lights(low beams) are the DRL's. I've checked the relays under the dash, flasher, brake and one unlabeled relay (this one tested good on the bench), does anyone have schematic of a 2000 - 3500 standard chevy?
New or old body style? If it is an old body style the relay is mounted in the convenience center under the left side of the dash.
Yesterday afternoon I went by the local dealership and found the part # and location(Yes it's under the steering colume next to the combination flasher,P/N 120770866),after test I found I do not have power to the light circuit #'s 30, 87,and 87a on the relay. I think it's time to buy the manual! Roger P.
hate drl's, how do i permantently kill em?
Just pull the fuse located in the electrical center under the hood,if you look under the lid at the diagram it will tell you which fuse is for the DRL's,just pull it out and thats it!! No more stupid DRL's. Worked on my '97,'99 and '04.
Hey, Have you guys ever noticed just about half the chevy trucks, suvs, the drl on the left side is always shot, just about every chevy truck i see its shot, :flag: i thought their would be a defect, but none yet.
