canyon/colorado
I own a Colorado Crew Cab, just a couple weeks ago i fitted it with some 15 by 8 MT Rims, so far i think its badass looking but its mostly up to the people who buy them for either traveling or something else.
  • 3 weeks later...
Got any pics??
I like the styling of the Colorado front end at least during the day. I don't however like the headlights on the bottom with the park lights up top. At night the headlight layout looks odd.
I'm sure it's all to do with the current trend to try to make trucks and SUVs more "car friendly", to better satisfy all those people driving the tiny / low slung cars around and some of who are always complaining about the "huge" trucks / SUVs (can't see around em, headlights are level with my mirror, bumpers too high in collisions; those types of complaints). :flag:
I think this is also the reason why my 4x4 TB sat so low compared to the Blazer it replaced, and why my '04 Silverado sits so much lower in the front than my uncle's '98. :cheers:
Got any pics??
Yeah, ill get some, im always out in the field so hopefully i'll get some time and take some mud pics! :jester:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
