Hypertech owners Q's
Program allows you to "adjust" or "tune" for other customizations outside of just "Hypertech Power Tuning", such as top speed, tire size, axle ratio, shift firmness, etc., etc.. Has anyone found the optimum "shift point and RPM" combo that delivers the most performance or SOTP feel?  Had the unit for a year, gives a great wakeup or SOTP feel to the 5.3, but can't quite dial in the shift point, RPM correctly.  Thanks in advance!  Look forward to your feedback when I wake up tommorrow. :thumbs:
On my truck I gain HP and speed by adding 2 mph to 1st.  I lose a little HP in 2nd by adding 3 MPH, but I gain a little speed and when I shift into 3rd at that point I am in my power band so my truck posts higher 1/4 mile times. (not like I care).  I left 3rd-4th at 0 because I want my torque converter to lock.  With 35's and 9" of lift it takes longer for my truck to get to speed, so with the converter holding all the fluid in it for acceleration I could damage it.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
