Has anyone out there tried the 295 Nittos in this size, particularly without a lift? They are about $20 each cheaper than the 285 BFGs based on Discount tire's website.
Also, does anyone have anything positive or negative to say about the Nittos, possibly about treat life?
Nitto Terra Grappler
LT295/70 R17 121R diameter-33.19 width-12.1
BFG AT
LT285/70R17/D 121Q diameter-32.8 width - 11.5
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 983 Guests (See full list)
