automatic headlight system
After I returned to my Blazer after a Hoilday party the Automatic headlights didnt come on...worked just fine getiing there.. :ughdance:
Drove home by using the manual switch. has anyone experienced this before???
Anyone know what the problem could be???
Thank you for your help
Scott
There is a trick to disabling and enabling the DRL's. Press the dome light buton 4 times with the ignition on and with the engine off. I think this works on 98 + model S Series.
Ive used the Disable before, the sensor for some reason wasnt working. this morning/ night its fine.....
Must have been a squirrel in the wires again??? :troll:
Thank you for your replys,
Scott
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
