2500 HD Suspension Problem
I have a '03 2500 HD w/the Duramax that has 9800 miles on it. I have the Fabtech 3" spindle lift with 285/75/16 Bridgestone Revo tires. Everything else is stock. The other day, going down the freeway, riding alongside the truck I noticed whenever the truck hit a bump or went across an overpass the tires appeared to flex outwards and out. I jacked the truck up to check play in the wheel bearing and found none. I then grabbed the tire at the 3 & 9 o'clock position and found that the suspension had alot of upward play in it. I took it to the alignment shop and the mechanic stated other than a few adjustments everything was within factory specs but I should take the truck back to Chevy and have them check the amount of play in suspension. I have read that the HD front end has had some problems but with only 9800 miles that truck isn't even broke in yet. Has anyone else experienced this problem?
I too would like to hear of these potential problems. I have a 3" fabtech spindle in this picture. I am at 6700 miles and I have had no problems so far.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 885 Guests (See full list)
