merry christmass!
J's 92
i hate this time of year.... because i hate snow!!! :dupe: its no fun unless you have a ricer... sliding all over the place. im now the master of ebrake 180's to reverse then 180 again to drive :seeya:
    Gkistler
    Gkistler
  • Who's Online   4 Members, 0 Anonymous, 926 Guests (See full list)
