LED Brake Light Housing
Ever since purchasing my 2001 Tahoe Z71 I have been looking for a LED Rear Light Cluster. I know there are LED replacement bulbs available. I am looking for the entire housing. Something similar to the way the Cadillac Escalade has an LED housing. The difference is I was and the LED's to create the color lights. Exactly what I am looking for is a clear plastic cover with Yellow, White and Red LED's to make up the Turn, Backup and Brake Lights. Can anyone head me in the right direction. I know this must exist I am just unable to locate them.
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
