Bristol Spring Tickets
Bud
If you don't mind me asking, why you selling?
Done with Nascar? :jester:
No I love to watch the races. I've had these seats
for about 25yrs. I have a bad back and can't sit that long.
Hope some day my grandson might want them.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 784 Guests (See full list)
