Noise from up front
chase
I have a 2000 Silverado Z71. When I turn my steering off center, such as taking an easy curve, I sometimes hear a metal to metal sound, like something contacting the front wheel rotors. When I straighten out alls well. I checked the front pad wear indicators and they aren't making contact with the rotors. Anybody else experience this?
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 757 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
