Passing in a white-out...........
millerwd
One of the advanatages of my commute is very little traffic. My daily communte takes me over Blewitt Pass here in North Central Washington. Most of the traffic is big rigs early in the morning.
This morning, 05:00, it was snowing moderatelyand the road was snow packed.
The road is two lane with sections of three lane, the right is for slower traffic.
The semi I was following was causing white-out conditons at about 45 MPH. About all I could see was the road in front of him and his rear trailer lights.
When the road widened to two lanes, one for slower traffic, I began to pass. All I could see was the trailer lights on the left side of the big rig. As I came up along side him I could see his tractor wheels then the road ahead. It was a real rush to just have faith in the driver that he was far enough right that if we met oncomming traffic there would be room for the three of us. Most likely the oncomming would be another big rig. I would be the odd man out,
On the curves my max speed was 60, at 61 I would start to slide. Braking was not an option.
People can make fun of the little SUVs all they want. But this Honda CRV with the studded Cooper ST2's is very predictable. Along with the manual transmission you can get just the right amount of torque to comtrol the vehicle. It doesn't have ABS which reguires the use of torgue to negociate stopping and turning.
God I love winter driving!
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,576 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
