Drafty foot wells
Just back from an Xmas trip in our AV.  The wife's feet were cold the entire trip.  There is a draft down in the passenger foot well.  It's near the upper right side of the foot well.  It's too cold to be out in the garage guessing.  Anyone have an idea where it might be?  How to find it?
I,m just guessing without looking at mine, but I would start by checking the filter to be sure it is set and closed up properly.The fresh air filter is located in that area, behind the glove box.
That sure sounds like it.  Especially with another discovery we made.  If we turn the fan up high enough the draft stops.
Guess it's a trip to the dealer.
Thanks
JohnC
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 906 Guests (See full list)
