Low Oil Engine Shut-off
I'm looking at buying a GMC Sierra repairable which was rolled on it's side. What I'm concerned with is, did the engine shut off soon to cause no damage or? Does the computer have logic to sense low/no oil and shut down?
Thanks,
Hookem
When oil pressure reaches near zero psi the fuel pump cuts off. So after oil pressure is lost it will only run a few seconds.
Hope this helps.
I'm not so sure the fuel pump is shut off when oil pressure is zero. I can't find anything that says that.
That was a common misconception on the older vehicles that used the oil pressure switch directly to supply power. It was really just a backup to the relay. If oil pressure dropped to zero on those, the relay still kept the fuel pump on. If the relay failed, you could crank it long enough to build oil pressure and get the vehicle started. Of course in that case, if oil pressure failed, it'd quit with no working relay to keep the pump on.
On the newer vehicles, the oil pressure switch is an input to the PCM. So it's possible that when the PCM sees zero oil pressure, it turns off the fuel pump which it controls. I just can't find that in writing anywhere. It would seem the smart thing to do, but they don't always do the smart thing. :) Guess I'll have to disconnect an oil pressure switch at work and induce a zero reading to see what happens.
There's definitely no inertia switch. That's a Ford thing I believe.
Hope this helps.
i'd like to know where u got that information.
older trucks used to run power to the fuel pump through the oil pressure
switch to allow for the fuel pump to power up once the engine built up enough
oil pressure in the case that the fuel pump relay was bad.
but i don't think the nbs trucks have system.
regarless only if the relay was bad would the fuel pump shut off once the engine lost oil pressure.
    Greg3160
    Greg3160
  • Who's Online   0 Members, 0 Anonymous, 446 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
