2005 Sierra w/ 22" Rims??
is it possible to stuff 22x9.5 rims into a 2005 GMC sierra 2WD?? also...what should i do about tire size? 295/45R22 maybe?? will something along those lines fit? let me know what you guys have done.
thanks,
Jacob
I think running a 22 X 9.5" rim without a drop kit should be fine. If and when you drop it, I think you will be having some rubbing issues even with a drop as conservative as a 2/4. Running a 45 series tire will definately help you out in the sidewall area, but may rub as well. I have a freind with a Tahoe running some 22" X 9.5" rim with a 305/45/22 and has no rubbing issues at all at the stock height.
I have some 22" X 8.5" with a 305/40/22 and a 2/4 drop kit installed and I have zero rubbing issues. There might be a butthair of clearance at full turn, but it doesn't rub.
Late- Alex
i was thinking about running a 295/45R22 with 22x9.5 rims, do you think i'll have rubbing issues stock?? or...what do you think will look good with no rubbing?? you guys know metric tires on american trucks a lot better then i do...my other truck is an 86 toyota on 31x10.50R15, see...that easy to understand.
thanks,
Jacob
Be careful running a big rim with a low profile sidewall. One big pothole and there goes your high dollar rim. I'm running 20's with 305-50's they fill up wheel well and look beefy besides. If I knew how to download pics to the site I'd show you.
Just my $0.02.
SS
Just my $0.02.
SS
i've thought about that whole pothole thing, but as i sit here and look at my work truck on 20s, i just think to myself, "a little larger would look a lot cleaner." plus...this is definatly gonna be a babied street truck.
Jacob
