Klasse/Zaino users
Any Klasse users out there? I have heard that after you apply Klasse water does not bead up on your truck it just sheets off- is this true? I have used Zaino in the best just looking at other options. Is Klasse as durable as Zaino is?
I did some research on this about a year ago. I ran across an independent study that did some testing on the different "waxes". Zaino was rated number one and Klasse was rated number two. However, it was noted that Klasse is a much easier product to use and much less time consuming to put on than Zaino.
I have not purchased any Klasse yet as my truck sits in the garage most of the time and is not exposed to the weather a lot. I have a coat of regular paste wax on it right now. I am going to buy some Klasse and the Glaze and use it this summer.
I've been using Klasse for about 3 years. I use the 2 step, first polish, then glaze. I LOVE it. It goes on/off VERY easy and lasts almost a year (In Chicago). Water does bead on mine for a good 8 months after treatment. I've used quite a few different waxes/polishes (never used Zaino) and Klasse is definitely my favorite.
Zaino doesn't take long at all - I can do three full coats on and off my Firehawk in 45 min and use the same towel to remove all three coats w/o any residue at all. With the new ZFX it eliminates the need for two products and lessens the cure time. Zaino is as easy to use as anything else out there if not easier. :cheers:
