FIPK
just ordered a FIPK today. I'm pretty excited. expecting it around tuesday. anything you guys could tell me heads up that might come in handy for the install?
thanks
:):cool::D
They're pretty easy to install. Take your patience pills though for the rubber sleeves that connect the tube to the throttle body and the mass-af sensor. They take a little wriggling but not too bad. It took me about 30 minutes. It adds a little more umph and it's a little noisier than the stock airbox. It kind of sounds cool, though. Mine didn't do anything for my mileage but others have claimed a mpg increase. Oh, you'll probably have to trim a notch out of the fan shroud to accomodate the tube. A utility knife works very well. No need for power tools there. :)
thanks for the help yall. I had a buddy who had done one before without knowing it. it was about as simple as i thought it would be. that rubber was a son of a gun trying to get it around the main plastic air pipe. most importantly, now she flies :banghead:
thanks again
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
