New Guy in Alaska
dbunn
Hi there. My name is Dan. I am a pilot for the Army and I am currently stationed up in Alaska. After I came back from Afghanistan I purchased a 2004 GMC Sierra 2500HD. So far the only thing I have done to it has been to add some Westin step bars, a Extang Tonneau Cover, and I threw a K&N Air Filter under the hood. Future upgrades that I am looking at is a hood deflector (bug deflector), 285/75/16 tires and most likely some new wheels to go with. That is actually a question I am going to pose in the forum. Also, I have been considering getting a Sun Chip Programmer in the future. Not much else other than that. I have 1 picture of my rig after I picked it up. I will take some more up to date ones and post them soon as well.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 620 Guests (See full list)
