4.3 runs lean - long!
Hey...I'm new here but in reading some of what y'all have been through with the 4.3, I can feel your pain!
I've been losing my mind with a problem with my 4.3 CPFI Blazer. I've spent more money on fixing this truck than I care to think about...but the problem has persisted over several YEARS. My g/f has been driving it for the past few years and finally bought a new car b/c she is tired of how it runs. The initial problem was the usual fuel injection spider problem...a couple of the injectors leaked badly and it ran WAY rich. I changed out the injector, cap, rotor, plugs wires, o2, fuel filter. It ran better but still surged a lot. The next year it failed the emissions test for high NOx. So it had problem #2, cleaned the EGR passage and valve, and it passed on retest. NOx was still high...but it passed. fast forward two more years to the next test, failed again for NOx, cleaned the passage and replaced EGR valve, passed quite well... shortly after that it started to act up again...stalling at lights, no code, supplement the idle and it was fine. Thats when she bought the new car...and the blazer became MY problem (as she put it!) I did find that advancing the timing 8 degrees made it idle more acceptable.
So the first thing I did was go through the basics, compression, cam lift, look for vacuum leaks, pull the upper plenum. I saw that a lot of people recommended changing the fuel lines at the same time as the spider so I changed out the fuel lines (nut kit). It has a few symptoms that confuse me. First things first, it runs LEAN...the plugs have absolutely no black on them. They were black when I changed the fuel lines and now they are white with lots of rust colored deposits on them. There is no high idle on cold start up...but cold is when it runs best. When it operates in open loop, it drives great with no discernable power loss. Once it hits closed loop, the INT and BLM numbers drop to under 100, which indicates that it is leaning out the mixture to "compensate" for a rich signal. I thought that the O2/02 heater might be bad so I put another o2 in it...with no change. If I disconnect the ECM and let it forget it will drive okay until it relearns its stupidity. As far as how it runs, it has sufficient power, but if you hold it at a constant speed, the engine surges up and down. idle at lights is about 500.
So...I have an OTC scan tool, access to Mitchell, service manuals. I'm determined not to let it beat me...what am I missing? I'd like to think I got it all but I had to have missed it cause it ain't fixed!!
Oh...and fuel pressure is 51-52 while running/driving.... and it doesn't set any codes...
Thanks for any help...
edit: Its hard to say if it detonates...i assume it does. I happen to be lucky enough to have one of the first balance shaft motors that has the needle bearings in the rear of the block instead of the oiled bearings...so the motor makes noise anyway.
there isn't a pattern to it...if thats what you are asking. As long as I'm cruising it is all over the board, .35, .8, etc. it isn't always lean or rich or worse, fixed. It seems to be operating correctly at idle and under cruise. I dont' understand why the computer thinks that it needs to lean it out. I think that the information that I get out of the scan tool is a little too slow to get an actual trend. I'm looking into an ALDL cable to use my laptop to datalog it. Maybe then I can see that the ECM is smoking crack!
At this point, it is less about having it run right and more about figuring out what the problem is. :seeya:
Todd
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
