HELP!!! Cats clogged or bad O2 sensors??
My '98 Yukon feels like it hits a brick wall at 3000 rpms. Check engine light came on, threw code for low voltage to bank 1 and 2, sensor 2 O2 sensors. These are behind the cats right? I think its cause of clogged cats, but how do I know if it isn't just bad O2 sensors? What causes cats to clog? Truck has 133,000 miles on it, just eventually happens over time? Don't want to put new ones on and wreck them in a hurry if there is a problem. Truck was running great until a couple weeks back when I started noticing loss of power.
If it is cats what should I use for replacements, GM or aftermarket? What brands and prices have you guys used?
You can check for a restriction in the exhaust system with a vacuum guage. Hook the guage up to manifold vacuum and start the truck. There should be between 17-22 in-hg at idle. When you open the throttle, the reading should drop...it'll go to 0 at about 3/4 throttle. When you snap the throttle shut, the vacuum should jump to about 25 or more immediately. If the reading comes up very slowly, the exhaust is restricted.
If both cats failed at the same time, I'd be looking for a runability problem before cat replacement. Did the problem start shortly after filling up? Maybe you picked up some bad gas.
Truck has been feeling like it has been losing power for a couple weeks now. There was also a cylinder 2 misfire code with O2 sensor code. I got a cylinder misfire code a couple weeks back too. Checked plugs, wires they all seem to look good. Plugs, wires, cap, and rotor replaced about 14,000 miles ago.
Couldn't a bad fuel injector cause a misfire code?? I'm thinking at 133K fuel injectors may need replacing? Seems like even under light load sometimes engine seems to skip a beat, feeling like a cylinder misfire.
Have you checked the fuel pressure? Sounds like you're running out of fuel more than anything.
Will the O2 sensor trip a code if it's too lean?
I would think the O2 sensor would throw a code if it were too lean.
On that topic what exactly does it mean when the code says low voltage detected? I know there is a range the voltage is suppose to fall within, but what does low voltage mean and high also??
I'm really wondering if I should take truck to mechanic and have it diagnosed cause we are dealing with lots of expensive parts here and I don't want to be throwing money at something that isn't broke. :crackup: Sounds like the misfire is the root of the problem. Bad injector?? I really don't want to tackle any project until I know what I'm after :devil:
Per the manual, a low voltage code from the O2 sensors means it is seeing a lean exhaust stream. A high voltage code is just the opposite - rich exhaust stream.
It does appear you engine is not getting enough gas...did you check/replace your fuel filter?
After doing some searching around here on this site. Looks like I'll be doing a fuel filter tomorrow AG Bill. Haven't changed it in 30,000 miles, so it could be the culprit. If that does not work then sounds like I'll go to the fuel pressure regulator next. Then onto injectors I guess.
Would these fuel problems cause the cylinder 2 misfire though?? :crackup:
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
