Stick Man goes postal
R Dogg 56
I resent that. :happysad:
more people are killed at school, adn convience stores than the post office.
Perhaps he went "scholastic" or "convienient"(sp)
You wouldn't want me in there. I would use that pretty tire iron to get out. Then while you were crying about it...I would use said tire iron to smite you about the head, neck, and shoulders. :nopity:
You'd have a heck of time getting me in there in the first place though. I'm scrappy. :wtf:
You wouldn't want me in there. I would use that pretty tire iron to get out.  Then while you were crying about it...I would use said tire iron to smite you about the head, neck, and shoulders. :mad:
You'd have a heck of time getting me in there in the first place though. I'm scrappy. :nopity:
who said you'd be moving? :D:fume::wtf:
lol, j/k
It was only a figure of speech. If it makes you that pissed off, then ask one of the moderators to edit it to your liking. Or you can do the next best thing and have them ban me for making you mad.
Either way, I really don't care anymore.
