Relocating Spare Tire
i'm thinking about making a bracket to mount it on the roof rack. has anyone done this before? i don't want it behind the truck because i have a hitch mount bike rack that i use.
i tried to search for this but the results come up one post at a time. is there any way to just see the topic?
The reason it comes up as single posts, is so you can determine whether or not you want to look at the entire thread.
Right above each post (after a search) you can click on the thread title, and it'll take you to the full thread.
As to your question...It shouldn't be too difficult to mount up there, but I don't know anyone on this board that's done it.
I just wish I could get mine out of the truck, and under the back end like yours. It eats up loads of interior space. But my gas tank is under the rear. :wtf:
mine is in the cargo area too, that's why i want to move it but the gas tank is in the way underneath.
anybody know of a good cover i can use over it? should it be hard or soft?
Really? I thought that they moved the tire down below in...Like '95 or so. :wtf:
I guess my girlfriend was right. I really don't know everything.23_28_113.gif
Putting the spare up on the roof isnt a very good idea for two reasons.
#1 It raises the center of gravity resulting in possible rollover chances in emergencys.
#2 It causes wind drag that reduces your fuel economy and probably will make noise. :nopity:
Yep, The 2 door and Suburban had the spare inside and a rear tank. The 4-door Tahoes and Yukes have it underneath and a side gas tank.
#1 what about people that have the luggage carries on top? why would the factory put a roof rack on there? i hope not for looks.
#2 i think with an angled hard cover it wouldn't make much of a difference. the tire won't be sticking more than a foot above the roof
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
