6 lug on 96 Silverado
My nephew wants to put my factory 6 lug 16 inch Silverado rims on his 96 5 lug Silverado, he said he’s seen it done. Anyone know if it’s possible and what is involved?
needs adapters, and they would stick out too far. He may be confused with the 4x4 1500 which has the same 6 lug pattern as the current 1500.
I will if you get the 6 lug spindles from the NBS trucks like yours. the adapters will work but they will move the wheel out another inch and they are not really DOT approved.
The NBS spindles won't work on the OBS trucks. Like i said the c2500 6-lug spindles will work.
first off doing that conversion does not justify the cost of changning the wheels...you would really have to like the NBS stock 6 lugs to perform a major suspension swap. btw, I belive the C2500 spindles are the same as a c1500 spindle, but just has a 6 lug rotor. as far as the rearend...you need adapters or you will have to swap the axle with a c2500 or a 4x4 1500, or a later model tahoe, escalade, yukon etc.... IMO... PITA for stock wheels...just find a nice set of cheap aftermarket rims and save money...
For the front all you have to do is get a pair of rotors for a 96 2wd 2500 (6 lug) and do a brake job. For the rear, I would think all you have to change is the axle shafts, not the entire axle. (the half tons all use the same rear end)
The spindles are probably the same, but you would at least have to have the hubs from the 6 -lug truck. What would you put the rotors on if you didn't?
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
