FRONT END SHUDDER
JUST BOUGHT 05 SILVERADO EXT. CAB 5.3L. I PUT MY 20 INCH VELOCITY SIX
WELD RACING WHEELS ON THAT I HAD ON MY TAHOE. NOW I GET A CRAZY FRONT END SHUDDER WHILE BREAKING. IM GUESSING IT HAS SOMETHING TO DO WITH THE BIGGER WHEEL AND WEIGHT AT THE CORNERS. BUT I NEVER HAD
THAT PROBLEM WITH MY 02 TAHOE...........FEEDBACK PLEASE....
Warped rotors?
Pull the front wheels and retorque the lugnuts correctly.
Hopefully the rotors aren't damaged now.
Welcome to the board!
Warped rotors?
I TORQUED THEM JUST LIKE ANY OTHER WHEEL..WHEN I HAD MY TRUCK IN FOR SERVICE TODAY THEY TOLD ME I HAD RUST ON MY ROTORS AND THEY TURNED THEM..THIS SOUNDS LIKE A CROCK TO ME BECAUSE YOU CAN CLEAN THE RUST JUST DRIVING...I THINK THE TECH WAS JUST LOOKING TO GET PAID...I WAS LEANING MORE TOWARDS TO MUCH HEAT ON THE ROTORS FROM THE NEW WHEEL WEIGHT AND SIZE CAUSING THE SHUDDER UNDER BREAKING...LIKE I SAID IM NOT 100% SURE...
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
