It's the little things.....
After the new heater core went in, I decided to correct some minor things.......first off, the steering wheel shroud had the base model chevy logo.....it should have the SS badge to match the others, so I ordered the SS shroud badge with the core, to make the badging correct.....
the Camaro betwen the tach and the speedo was black, and I believe it was supposed to be white, so I tacked that next.....I first used a popsicle stick too get most the paint on by painting the stick and then pressing the painted side of the stick with against "camaro", then I used a toothpick to touch up what wouldn't stay... I like it White much better, matches the passenger side large camaro bacde which has a white center:
you can see the SS badge in teh "before pick".
Next I gotta get a new seat belt buckle cover.
oh yeah got her up to 4000 RPM on the highway......not QUITE triple digits. and before you guys freak out, thats a little under 2/3 max engine speed, 2/3rd's is the max during break in(at least from the stuff I've heard). I'm 9 miles from 250, so tomorrow is the first oil change, I've decided on Valvoline VR1 20-50 for the rest of the break in.......not sure weither I'll switch to Mobil 1 after that and risk a new leak(new seals, but it's still an "old car!"), or stick with the VR1.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
