about the 05 Burb
Buying a 05 burb, I have a few questions.
1) is the flex fuel engine a safe bet, it seems its the only 5.3 around ?
2) Dealer says they will install the DVD system themselves, is it the factory and qaulity or some cheesy after market deal ?
3) with these new 3:43 gears is it a dog. had an 04 with 3:73 and was pretty peppy
4) If I wanted dif tires then stock brand would dealer make a deal ? same size
Scott
I'm not sure about the other stuff, but I can help you with the gears. It should be fine if you don't tow alot of heavy stuff. My mom's Tahoe has them and so does a buddy's 2001 Yukon XL. He even pulls a light utility trailer with it occasionally.
1) Yes. No problems
2) Most likely cheesy aftermarket deal. I'm not aware of any GM accessory installation package DVD system. Keep in mind any aftermaket component would not be covered under warranty no matter what they tell you.
3) That's a matter of opinion I'd say. Seems peppy enough to me.
4) I don't know what kind of deal you'd want. You'd pay for the priviledge, that's for sure.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 842 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
