hello everyone, i just bought a 1500hd 2wd last month and i have really enjoyed reading this forum.
hope to join in on all of the conversation
Welcome to the forum txg.  Nice choice for a "daily driver"!  Be interested to hear your 2WD MPG vs the 4WD 1500HD guys.  I'm looking at a 1500HD CC SB, for my next truck, so share your likes and dislikes when you've had time to find some!  Again, welcome -
Nice to have ya here.  Hope you don't mind me saying this, but I personally am more interested in hearing any comments you have on your "ranch truck".   :)
txg,
I'd love to see a pic of the 1500HD with the Westins on it.  I've been back and forth as to what I want to put on my truck...
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
