700 r4 swap
What modifications to the driveshaft and cross member do i have to make to swap a 700 r4 in place of a th400?
The truck is a 78 stepside...
Thanks...
warren
I'm not sure about the mounting mods, but have you figured out the lock-up converter? It needs to have an electrical input to lock at the correct  load, rpm, and gear combo.
Why are you changing? The TH-400 is a really solid tranny, but I've never met anyone with a 700 that didn't have trouble. If it is strictly the OD that you're looking for, you can buy an aftermarket OD to put on your rig.
Warren,
Make sure you get one of the newer ('87+) units, or if you have an older one make sure it has the heavier duty parts installed.  In fact, whichever model you choose I would recommend having some aftermarket heavy duty stuff installed, these trannys are known for failing after less than 100K miles when stock.  I would try to get one out of a newer Suburban or pickup and have a professional rebuild with hi po parts.  I have been considering this same swap for my 454 Suburban.  There are a couple of manufacturers out there making electronic lockup kits for the 700R4.  By the time you have bought all the stuff you may be near the price of a Gear Vendors Overdrive.  Bolts onto the back of the TH400, driveshaft mod, and you're ready to go.  Stout as ####....
Something to think about.
Jeff
www.jeffsclassics.com
Warren,my 89 700  r4 is stock nd original with 145 K on it,and i plow and tow.I even gross out at 9000+ all winter with my V-box spreader in the back and Fisher plow.I dont think you'll have troublewith one if its set up properly and you install a large auxilary cooler.You need to get one out of a truck to work best,and dont worry about the lockup-its not a huge deal to hook up,it is essential though,you can buy a lockup kit from B&M if you dont know how to make it work.You can probably slide the stock crossmember back about 3" on the frame and drill new holes.The driveshaft,try to get the one with the 700-and you need a truck output shaft and yoke-it has 4" of travel-the car ones only have 3".You will be deshafted (dropped driveshaft )if you use the car shaft and yoke,so dont make this mistake on a truck.The single most important thing on this swap is correct TV cable adjustment-if the kickdown cable is out of adjustment-the tranny will burn up-in as soon as 50 miles if its really out.The tv cable(kickdown) is the only wa the tranny knows how far into the throttle you are-it has no vacuum modulator like the th400/350.so if its out of adjustment and your into the throttle the line pressure will be low,and it will slip the clutches in the tranny-a few times and they are toast,so get the right bracket for your carb,and get that puppy adjusted right.If it feels like its short shifting its probably out of adjustment.Good luck ,
Check out the new Jet 700R4. They make one without the electronic lockup and its supposed to be bullet proof.  The web site is www.jetchip.com All of the 4wheel drive magazines I have gotten have raved about it.  It is designed specifically for what you want to do. :cool:
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 769 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
