Anyone know if there is touch up paint for the interior vinyl. Specifically door panel? I have a nasty mark on the drivers side and would have to replace the whole panel or maybe paint it.
I know our body shop can mix up paint for vinyl and interior trim.
That would be cool if possible? I only need a small amount. The previous owner somehow got some glue on it and attempting to remove it has left a blemish approx 1inch in diameter. Its not too bad but you can see it. A dab of matching paint would likely hide it.
check your local auto parts store, most carry vinyl paint
when I bought my truck it had a cig burn on the vinly by the window. This body shop gut filled in the burn and repainted the spot to match perfectly.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
