MPG decrease
I went from 14.5 mpg to 11 mpg within 1 month. i have a 98 2500 350vortec manual trans. i changed the fuel filter, air filter, pcv valve and ran injector cleaner for 2 fillups. I have not done a tune up but I did check the plugs and they look fime. I have also notices a loss of torque at low end. I used to be able to chirp the tires from a slow roll now it seems to "gag" until it hits 1800 rpm. :confused: Any one have some suggestions.
Thanks
Jim
No cel, I guess ??
O2's KILL your mileage when they go bad, and I've seen them go bad-enough to kill mileage but not set-off the cel.
Might be something to look at...
Did you check the plugs before or after this power loss occured? You might have broken a plug wire while removing it.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
