03 radio upgrade ?
I've got a basline 03 GMC Sierra, with just the basic radio without theftlock. I want to upgrade to a single disc with RDS. I have found a couple, but after talking to my local dealer, they tell me that they do not think that my pickup will support this radio, but I can bring it to them and they will program it for $45, cause they have to hook up the computer to it. If I get one without RDS I can use the press and hold 2&3 buttons programming trick, myself. I would like to have one with RDS, but I dont want to spend the money only to find out it will not work for me. If I get one without RDS will it work in my truck, without having to take it to a dealer to have it programmed? Also, will any 03 and up factory GM stero without RDS work in this truck, or does it have to be one specifically for trucks?
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 549 Guests (See full list)
