when to soon for syn oil
How long do you have to wait before you change to mobil 1 oil ? I have about 3300 miles right now. I heard that 20000 should be the time
Scott
You heard an urban myth. Anytime will be fine...
Is 100000 too late?
But, if you already have damaged seals (from running low on oil or not changing the oil often enough), any good synthetic may clean away the sludge crust and allow the existing leak to show itself.
Also some people find that they consume a little more oil in an Oil Change Interval with Mobil 1. I did - 0 qt on Havoline 10W30 - 1 qt on Mobil 1 10W30. 9,000 mile OCI by Oil Life Monitor... Many of those people also say the consumption goes away after the first or second Mobil 1 oil fill. Personally, I switched back to the Havoline...
I did my first oil change on Friday 5-27 at 3290. I had 5-30 Mobile One put in along with a factory filter. By the way, the service manager stated that the 5.3 for some reason didn't like the Fram filters. I don't know what this was about, but he also said that he liked the Mobile oil filters as well, so it didn't seem that he was trying to puch the delco stuff.
Maybe the service manager had been on the Bob is the Oil Guy Website and had read about the "quality" of Fram filters. If 1/2 of it is true then I imagine not only would the 5.3 not like a Fram filter, but a 74 AMC Pacer wouldn't be too crazy about the idea either. Personally I don't think you can beat a Delco for a GM product; there are other great alternatives, but Fram almost never is on that list. BTW: Started with Mobil 1 5W-30 at 3000 miles; I've had no oil consumption or other problems since. As stated above the "no synthetics" before _______ appears to be an urban myth.
vroten :thumbs:
You can change over now,You'll be fine,I changed over at 11,000 miles.
And like others have said,A lot of GM cars (Corvette,Cobalt SS,SSR,GTO,XLR,CTS-V) come with Mobil1 from the factory.
:thumbs:
:P
There is no harm in running synthetic from day one. The old days of letting the "seals" set with dino oil are past. These engines require little or no break-in time.
Changed over to M1 at 500 miles,then changed at 1,000,2000,5000,10,000 and every 6k after that...No consumption,no problems,did the exact same thing with the wife's 03 Impala and on the same regimine with the daughter's Aveo....
For those using 5w and 10w30 M1 try M1 truck & suv 5w40,especially you LS1 powered guys,my truck hasn't been more quieter,peppier and I haven't been happier... :thumbs::P
Now for the "Question".
Now that we all have the Mobile 1 pumping through our veins...do we trust the computer to tell us when to change???
At 3290, I had about 62% oil life left according to the computer.
On my VW Golf TDI that I traded in I went to 10,000 at every oil change using Delvac (Mobile's best Oil for Diesel engines). You could realy tell the difference with the feel between your fingers with the delvac and Rotella Syn. The rotella wasn't exactly gritty...but it wasn't as slickery...if you know what I mean.
...anyways...back to my question. GM provides 36,000 warantee with our trucks. If I was a betting man, I think you could get by with one change in that range. Now the longevity of the engine would be suspect...but it would make it.
Do we...or should we trust the computer?
Absolutely!
Perhaps this will ease your concerns...
GM Oil Life Monitor
From bbobynski on www.bobistheoilguy.com
One thing I can touch on and clear up.....the GM oil life monitor operation and my statement that ZDP (or ZDDP as you tend to call it here...most of the API literature just sticks to ZDP so I tend to use that) depletion is the basis for oil deterioration.
My spelling is poor but ZDP stands for zinc dialkyldithiophosphate which , as it sounds, is an anti-wear compound comprised of zinc and phosphorus.
ZDP is dispersed in the oil so as to be at a potential wear site if a surface asperity happens to break thru the oil film thickness causing the dreaded metal-to-metal contact. A molecule of ZDP must be present at that moment to prevent microwelding at the contact site which will cause material transfer, scuffing, scoring, wear and catostrophic failure. The concentration of ZDP in the oil will determine if there is ZDP present to work it's magic. The greater the concentration...the more likely a molecule of ZDP will be there...and vice versa.
By nature, ZDP is sacrificial. As ZDP is "used up" at a wear site to prevent microwelding the concentration of ZDP decreases.... So...if you measure the ZDP concentration in engine oil in a running engine it will decrease at linear rate based on engine revolutions. Any given engine has a certain number of high potential wear areas where metal-to-metal contact could occur due to reduced film thickness and/or surface asperities....areas such as rubbing element cam followers, distributor gears, rocker arm pivots, push rod tips, etc...... The more of these areas the more ZDP depletion. The more often these features come in contact the greater the ZDP depletion. That is why, generally speaking, ZDP concentration in the oil, for any given engine, will decrease at a fairly linear rate when plotted versus cumlative engine revolutions. The more times it turns the more contact the more chance for wear the greater the depletion. This is as much of a fact as I could quote ever and is really not speculation or anything. It is proven beyond a shadow of a doubt in many studies. That is why it is ONE of the basis for determining oil life remaining and why it is THE basic premis of the GM oil life algorithm. It is only ONE of the things that determines oil life...but it is the one thing that can be tied to engine operation in a linear fashion and estimated very accurately by accumulating engine revolutions via a counter.
The GM engine oil life monitor counts engine revolutions and accumulates the number for the basis of the oil life calculation. It then adds deterioration factors for operating temperature, start up temperature, soak times, ambient, coolant temperature, etc... There are a LOT of factors that "adjust" or affect the slope of the deterioration but the fundamental deterioration is traced back to the ZDP depletion that is inescapable with engine revolutions. The specific rate of ZDP depletion is readily measurable for any given engine so that is the fundamental item that is first calibrated for the oil life algorithm to tailor it specifically to that engine.
You would obviously like to get the oil out of the engine before the ZDP concentration gets so low that it is ineffective at being at the right place at the right time and preventing engine wear so that becomes the long term limit on oil life for that application.
The other things that determine oil life such a acid build up, oxidation, petane insolubles such as silicon from dust/dirt, carbon or soot build up from the EGR in blowby, water contamination, fuel contamination, etc.... are all modeled by the multipliers or deterioration factors that "adjust" the immediate slope of the line defined by the engine revolution counter as those items can be modeled in other ways and accounted for in the immediate slope of the ZDP depletion line.
The algorithm was developed over the course of many years by several lubrication experts at GM Fuels and Lubes, spearheaded by Doctor Shirley Schwartz who holds the patents (with GM) for the algorithm and the oil life monitor. I had the luck of working directly with Dr. Schwartz when the idea of the oil life monitor first progressed from the theoretical/lab stage to real world testing/development/validation. There were fleets of cars operated under all conditions that deteriorate the oil life for any and every reason and , thru oil sampling and detailed analysis of the oil condition, the algorithm was developed, fine tuned and validated to be the most accurate way invented yet to recommend an oil change interval by. As just one example, I have seen cars driven side-by-side on trips, one towing a trailer and one not, for instance, to prove the effectiveness of the oil life monitor in deteriorating the oil at a faster rate just because of the higher load, higher average RPM, higher temps, etc...and it works flawlessly.
The oil life monitor is so effective because: it is customized for that specific vehicle/engine, it takes everything into account that deteriorates the oil, it is ALWAYS working so as to take into account THAT INDIVIDUALS driving schedule, and it tailors the oil change to that schedule and predicts, on an ongoing basis, the oil life remaining so that that specific individual can plan an oil change accordingly. No other system can do this that effectively.
One thing is that I know personally from years of testing and thousands of oil analysis that the oil life algorithm works. There is simply no argument to the contrary. If you don't believe me, fine, but, trust me, it works. It is accurate because it has been calibrated for each specific engine it is installed on and there is considerable testing and validation of the oil life monitor on that specific application. NOt something that oil companies or Amsoil do. They generalize....the oil life monitor is very specific for that application.
Oil condition sensors in some BMW and Mercedes products are useful, also. They have their limitations, though, as they can be blind to some contaminates and can, themselves, be contaminated by certain markers or constituents of certain engine oils. Oil condition sensors can only react to the specific oil at that moment and they add complexity, cost and another potential item to fail. One other beauty of the GM oil life monitor is that it is all software and does not add any mechanical complexity, mass, wiring or potential failure mechanism.
There is considerable safety factor in the GM oil life monitor. Typically, I would say, there is a 2:1 safety factor in the slope of the ZDP depletion curve....in other words, zero percent oil life per the ZDP depletion is not zero ZDP but twice the concentration of ZDP considered critical for THAT engine to operate under all conditions reliably with no wear. This is always a subject of discussion as to just how low do you want the ZDP to get before the oil is "worn out" if this is the deciding factor for oil life. We would tend to be on the conservative side. If the oil life is counting down on a slope that would recommend a 10K change interval then there is probably 20K oil life before the ZDP is catostrophically depleted....not that you would want to go there...but reason why many people are successful in running those change intervals.
Please...NOT ALL ENGINES ARE THE SAME. The example above is an excellent practical justification of why you would want to add EOS and change the 15W40 Delvac in the muscle car at 3000 miles max and yet can run the Northstar to 12500 easily on conventional oil. You must treat each engine and situation differently and what applies to one does not retroactively apply to others. This is where Amsoil falls short in my book by proposing long change intervals in most everything if you use their oil. It just doesn't work that way. You can run the Amsoil to 12500 with no concerns whatsoever in the late model Northstar because even the oil life monitor tells you that for conventional oil off the shelf. Would I do that to the 502 in my 66 Chevelle...NO WAY. Amsoil says I can though. Wrong.
There are entire SAE papers written on the GM oil life monitor and one could write a book on it so it is hard to touch on all aspects of it in a single post. Hopefully we hit the high spots. Realize that a GREAT deal of time, work and energy went into developing the oil life monitor and it has received acclaim from engineering organizations, petroleum organizations, environmental groups all across the board. It is not some widget invented in a week and tacked onto the car.
The oil life monitor is not under the control of a summer intern at GM Powertrain per an earlier post....LOL Not that a summer intern wasn't compiling calibrations or doing a project on it but is under control of the lube group with a variety of engineers directly responsible that have immediate responsibility for the different engine families and engine groups. The idea that a summer intern was responsible for or handling the oil life monitor is ludicrous.....LOL LOL LOL
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 487 Guests (See full list)
