Front seat lumbar
Mattt
The lumbar adjuster on my front drivers seat no longer works. The knob spins, but no lumbar. How is that knob hooked up to the actual lumbar support in the seat back? Is this an easy fix, or do I just live with it?
the knob has a cable that connects to the knob and a plate located in the seat back. When the knob is turned, the cable is shortened and that bows the plate, which gives you the lumbar support. Just unhook the seat skin on the bottom of your seat in the back and you will be able to see all of this. I lost my lumbar in my drivers seat and when I opened the seat up I found the cable came undone from the plate. Very easy fix, just put the hook back into the hole on the plate and it has been fine ever since.
Thanks for the reply. Your excellent description got me to looking. Got the seat back apart, and looked up in there. Getting the seat skin apart at the bottom was a bit tough, I was thinking I was going to break the plastic guides.
Anyhow,,,,cable is hooked up, however, the tab that the spring hooks onto on the plate has broken off. The spring Im talking about goes in between the cable and the lumbar plate. The tab is part of the lumbar plate. No way to weld the tab back on w/o complete disassembly of the seat, or fire. Ive hooked the spring in another hole, but that makes for some lumbar support all the time. Drove it tonite and decided its too much lumbar full time. back to the drawing board for a fix.
Thanks again for the description to get me started.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 993 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
