I ordered a high pereformance thermostat online from Summit Racing. According to the site, Perma-Cool, Mr. Gasket, etc., all make the brass high-flow style. Now that I have it I checked the Helm manual and it indicates that the thermostat and housing cannot be separated and are replaced as a single unit. Before I unbolt the housing, does anyone know if this is true or just a ploy by GM to get you to buy the whole housing?
What thermostat/housing would be recommended then? And where can I buy it?
Thanks.
Thanks.
On my 01, the thermostat and housing are 1 integrated unit. I opted for a Hypertech 180 degree replacement that I believe I got from Truckperformance.com.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
