GT 40
SnakeEyeSS
does anyone else notice the horrid build quality??? The panels' gaps and alignment are VERY bad. I saw one on a route early in the week, they are sweet, but for a 150K car, I'd expect better panel gap spacing than a 4th gen f-body!
all you have to do is look in that Motor Trend Article a few months ago, those pics will show you what I'm talking about, look at the rear bumper.
I heard that ALL were recalled because of A-Arm problems. They were to brittle and breaking.
If I were to spend that kind of money on a car, it would be from someone who has been building that quality of car for a long time, not just a "one shot johnny".
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
