ABS light after gear swap
pcrow
OK, I give up...this one has me stumped.
2003 2wd 4.3V6. Origionally 235's (29") with 3.42 gears. I changed tires to 265's (30.55") wnd re-programmed with Hypertech III...no problems.
I have now replaced the gears with 4.10's and reprogrammed again for the gears. Now the ABS and brake lights come on within 5 miles after startup.
What gives?
Sorry, Acording to the Hypertech, there are none...I have checked multiple times.
BTW...shut it off and restart it, and the lights, and DIC message go away for about another 5 miles or so, then re-appear.
If the ABS light is on, there's gotta be a code. Well, okay, I suppose in rare instances there may not be, such as if the ABS lost power. I'm guessing this hypertech thingy, whatever it is, just isn't capable enough.
If I had to guess, I'd say there's a speed difference between the front wheels and the rear wheels as far as the ABS is concerned.
Thanks. 4Wheel Parts (the gear installer) told me to start reducing the tire diameter (as far as what I tell the Hypertech) until the lights stay off. I'm not sure I'm comfortable with that...seems like it will throw off the speedo, shift points, etc.
I plan on trying to get the codes read this week, as Hypertech says there are none...
I did get rid of the lights though. I told the hypertech about the 4.10's but told it I had 29" tires (actually 30.55 measured by 1 rev on pavement). Speedo is way off...unacceptable.
I actually did get the lights to go off...lied to the HP-III and told it I had 29" tires! Speedo is off, so i doubt I will leave it that way.
Update...
I called Hypertech this morning. They stated that they have had numerous reports of this...that particular combo yields a diff between the transmission output and wheel sensors that the ABS unit does not like. Hypertech says the only fix is to lie about the tire size (like I am now), or try to get the dealer to re-cal the ABS unit. they report that some dealers will (for a price), and some won't period.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 414 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
