8.1l dual tanks
Any one know of a company putting out a dual tank option or replacement gas tank for 04 8.1L 2500hd cc sb 4x4?Just cant get very far on 26g. tank when towing.Would be nice to have the security of the extra fuel.I really dont understand why they would put such a small tank on a truck that at best gets 9-10 miles to the gallon when towing a descent load.Even on the open road not towing i get about 13 and I have to usally stop for gas 30 miles before my destination is real annoying.
If you don't want to spend the big money on a transfer tank a couple of 5gal metal tanks strapped in the bed would serve you pretty well. I am considering this option myself.
I figure an auxillary tank with 30 or 50 gallons is already expensive, plus you have to carry the extra weight around when it is loaded.
gas = ~6lbs per gallon
diesel = ~ 7lbs per gallon
(these are approximations from looking at several websites)
For gas thats (30*6=180lbs) or (50*6=300lbs) extra weight plus the tank weight.
Diesel is goign to be around 210lbs for 30gal and 350lbs for 50gal.
I read a 'rule of thumb' that said for every extra 100lbs, you will loose .1mpg which I would guess is about right.
But a 56 gallon replacement tank would be nice! The question is $$$$$.
:chevy::)
Thanks for replys.Tierod I called transferflow they do have some options but not for my truck do to califonia emissions the salesman on the phone said sometime this summer 45gallons is going to be about $800-$1000.If i do it Ill lt ya guys know.Knez
Transfer Flow is the only one that makes a replacement tank (45g for the stock 26g) for the 2500HD CC SB. It's about $900 list (and I can't find anyone who will sell it below list) and if you have someone install it it's another $240 on top of that.
I was hoping to find a tank from a 3/4 ton suburban that would fit where the spare tire is but.... no luck so far.
Two tanks requires redundancy, two pumps, level sensors, wiring, hoses, vapor canisters, etc.... It would probably(definitely) be cheaper if we could get a group purchase on the 45g Transfer Flow tank since all the parts swap from the original and you can do it yourself.
My 85 Ford has the standard frame tank and an auxillary tank (19g) that fits OVER the spare tire under the bed. I wish it would fit.
DEWFPO
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 506 Guests (See full list)
