what's in a tune up?
I hope this is the right forum. I have a 2001 2500HD with the 6L gas engine.
I"m trying to figure out what constitutes a 'tuneup' these days. Besides
spark plugs & wires what does one check on an engine with injection instead
of carbs and apparently no distributor? How do you check ignition timing
without a distributor to rotate? Is the only option now to take it to the dealer
& plug the engine into their expensive diagnostic computer?
thanks,
thanks,
Fuel injector flush is the next most important thing. A new fuel filter. Air filter. PCV valve if equiped. Clean the MAF. Check for vacuum leaks. Change the coolant. 100K would be a good time to replace the cam and crank sensors.
Vernon
    JustusTX
    JustusTX
  • Who's Online   5 Members, 0 Anonymous, 661 Guests (See full list)
