Auto Climate control
My climate control has been givin' me fits the laast couple of days. When I change the temperature setting only the driver setting will change, so I will set the control back to auto then change the temperature again a few minutes later and again only the driver setting will change. This doesn't occur all the time but somewhat frequently. Is this something the dealer can fix easliy or should I wait till the problem occurs all the time before I take it in for service.
Are you holding down the Auto button until it 'resets'?
I've only had to do it once in my truck, but I think it might make a beep sound in addition to displaying the double arrows that indicate both driver and passenger temps are the same. I know that it took me going back and rereading the owner's manual to figure out exactly what I was supposed to do to lock the temperatures together. Before that I thought maybe it was random or something. And it just figured that my wife seemed to always change the passenger temperature right after I'd stumble onto the locked mode.. :jester:
I would reset it according to the manual adjust the temperature and it would work for a while, then a few minutes later I would adjust the temperature and it would go back to individual selections.
You have Dual Zone climate control. If at any time some one changed the passenger side setting it breaks free from the drivers side setting. To get the temps both the same and to keep them the same and controlled off of the drivers side knob- Press and hold the auto button for 5 sec untill the auto light comes on. Once the auto light comes on they should change together from the drivers knob untill someone touches the passenger side setting.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,017 Guests (See full list)
