Wiring A Brake Controller
kwasyd
Hello.
I have an 05 Chev DMAX 2500.
I want to hook up my brake controller.
I connected it the exact same way I did in my 01 1500 and it works.. except my sunroof will not close.
I have disconnected until I can get some advise on why it may be different and how the sunroof might interfere.
Thanks
Are you using a connector that came with your '05 or are you trying to use the one you had in your '01? They are wired differently.
Seen an issue with headlights when the wrong connector was used, though I can't say I ever heard of a sunroof not working.
Yup, the '01 is different. I had to move the red wire on the harness from one corner to another when I hooked up the brake control to my '05. They changed a couple years back. Sorry, but I don't remember right now where it was or where I had to put it. I'll pull it out later and try to give you an idea/ diagram. I'm pretty sure I found the info online though. Have you tried a google search? Don't know what to say about the sunroof....
Yah, I am using the 05 harness. I let the 01 go with the sale of to 01. So I have the proper GM harness. It looks the same, color wise.. so my assumptions were to connect the same color wires as I did with my 01. Bad assumption obviously.
I did a google search but didn't find much. I will have to spend some time, testing the outputs on the harness and then figure out where they would have to go on the controller. I appreciate the effort and information.
Thanks gents
The following information is for the 2003-05 wiring harness.
Pin
Wire Color
Circuit Number
Function
A
BROWN
2409
Brake controller illumination
B
RED
242
Brake controller 12 volt source
C
DK BLUE
47
Brake Controller output (Trailer Brakes)
D
LT BLUE
1620
Stop Lamps
E
F
BLACK
1850
Ground
  • 1 month later...
Hey Guys.
Here is what I discovered..
I looked at the wiring that you provided and some others I found online. They all really said the same thing. I then looked at my wiring and found I had it wired exactly as described.
Here is what I think it was.. as odd as this is. The day I hooked up the controller I had my sunroof open. I connected the harness and headed down the road. Once I got to the campsite I tried to close the roof and wasn't able to. It would go from slid open to slid closed, but not drop close. I guess having it open when connecting confused something. Anyway, this time I connected when the roof was closed and all works fine.
Strange hey!?!?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
