Whiplash suspension?
I haven't had much help about what to do with adjusting/modifying my front end to get the clearance i need to run 39's....so, i've decided to go with a bigger lift for that reason and because some other truck rivals in my area...Has anyone heard of this brand and if they are any good. I would also like to go ahead and mount up some 44's while i'm at it. :chevy:
Oh yeah... with this being a 14'' lift on top of having my 3'' body i should't have to worry about rubbing at all...right?
IMO, SAS.
Unless you don't plan on wheeling it.
I just read your other thread about your suspension woes...do you really think a bigger IFS lift is the answer? The kind of rubber you want to run requires more strength than your axle can provide if youa ctually use the truck in places that warrant 44" tires. So again, my vote is Solid Axle Swap.
I've read in so many magazines that anything over 6" or 35" tires are not recommended for IFS. You see them around, yes, but how many people also drive without changing their oil?
Well, atleast for offroading... why else would you want a lift though? LOOKS?
Gotcha... I didn't understand what you meant by "sas" How much trouble is it to convert to a straight axle? That would take care of trying to keep the front end aligned, and compared to an IFS, how much rougher is the ride going to be?
Well to be honest it is on the road more than off... but being 16 I'm always trying to find a new mud hole to try.
A kid with money to burn... nice ;) How fast you take those mud holes? Those are probably the most dangerous to get into since you'll never know how deep, or what's down there. Add a weak IFS to it, and you bound to get yourself into trouble.
A SFA would be much cooler anyways. Spend money on that.
If I go with a SFA I'm gonna want to go bigger because i know it's easier to get more lift with straight front... so here is my problem with that. My dad dosen't want me to go TOO radical with it, but he's all for the bigger IFS... What to do? What to do? :cheers:
What to do? Easy. Decide what you want to do with your truck. If you want to be safe and go off road, SFA. Simple. If you want just for looks on the street and stay cheap, I guess you could do IFS then I guess.
Whats the obsession with having a monster truck? do you think bigger is better when it comes to offroad? I'll bet you that a rig on 35's, will outperform your truck on 39's. Low COG if your gonna wheel it over anything more than mudholes. If its a mud truck, then I can see the reason behind these mile high lifts, but even then like stated above YOU WILL BREAK s**t in the front end.
If I was doing a SAS...i Would at least look to get a 60 under it. Also the ride woudl probably be even better, if you know how to properly set up your suspension. Get some coilovers, triangulated long arm up, would also give you the ability to add hydro assist to turn thos emassive tires. Not to mention it will open up a whole new rangew of gear sets that you could compensate for the larger tires with....cause I know for a fact a 4.56 isn't even close to deep enough g ear for a 39.5 tire.....hell I have 4.88's w/ 37's on my rig, and 5.38's w/ 37's for the comp. rig.
I realis eyour young, and I don't know if your funding this or not, from your other threads it sounded liek the parents were picking up the tab. But if you are, a d60 can be found at almost any boneyard, and could easily be overhauled by you in your spare time, and upgrade it as you get the $....once your done with that save the $ for the coilovers, and then start cutting and fabbing.
Thanks for all of the suggestions. More than likely I am going to end up with a SFA. and about the motor... we are going to pull the old one out and put another crate 350 in it with a blower and some other goodies. The only rush with this truck is I want to get everything i want done on it done before this time next year because it'll become my extra toy and i will be too tied up doing all of this stuff to a new 2500. :cheers:
    whenindoubtuseahammer
  • Who's Online   0 Members, 0 Anonymous, 269 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
