f/s stock wheels and tires
I have a set of 2000 z71 wheels and tires. the tires are goodyear size are 225/70/16, they have about 90 % threads. asking 400 . I prefer to sell them in SA, or any where close to SA. you can reach me at [email protected] sometimes I dont get to check my email till late. so if I not get of hold of you that same day i'll email you the next . laters Joe
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
