projection beam lamps
i just bought the "matrix" angle eyes projection lamps for my seirra the other day wasnt bad went to sporttruck direct .com to buy them it cost me 324.00 w/shiping to get them here to maryland but curious how the angle eyes thing works someone told me they hook to your parking lamps .. just curious i dont have them yet so not shure how they work i will post something when i put them on maybe a pic...
I bought mine from Ebay 4 months ago, paid about $175, I don't remember the brand name though, but they look awesome! I hooked up the angeleye rims to the parking lights and don't worry about adding more consumption to the circuit, the rims use magnified LEDs so they use so little power.
Take a look, its kind of a low quality pic
macifre,
How do you feel the quality is of the beams on the angel eyes you bought? I may use them but I am curious...they are not compatible with aftermarket HID's so I'd be curious what bulb you are using?
Also, i noticed the outside three led's are not lit? did you not wire them or did you not buy the newer model with the extra three LED's by the side reflector?
Thanks for any info :chevy:
Just a comment...
I am building new headlights for the 91-96 Impala SS/Caprice and did quite a bit of research on the manufactureres and technologies out there today for automotive headlamps. Since BMW introduced the Angel Eye a few years ago, it has taken a while for that look to catch on..however it is now gaining momentum. Several overseas (China, Taiwan etc) shops have begun introducing new "projector" headlamps with AE's. While I personally like the AE's and the fact you can hook them up to your parking lights or another switch, what is troubling is the lack of perfromance of the projector/main lighting assemblies. In doing my investigation for the best optics I could find, I talked with one "overseas" company and a few consultants and the consensus was that the appearance/aesthetics of these are appealing but the performance is lacking.
NHTSA has also craked down heavily on importers and retailers of HID retrofits...installing HID bulbs in housing/headlamps designed and produced with/for halogen lamps (9004, h4, etc.) Because of this, manufacturers are being cautious as NHTSA has fined several companies providing non DOT spec HID's to the market. I don't believe the overseas manufacturers of these AE/Projectors offer them with HID options...probably due to cost, lack of technology or ability to test them to meet proper NHTSA lighting standards.
Since my Impala project will be wrapping up here soon, this might be a worthy project for me to investigate.
I would be interested to hear from owners of these how they feel the light output was.
hey thanks for the reply guys i finaly got mine in and installed wow there sweet i ordered them from sport truck direct not bad but it was about $300 (should of bought form e-bay..lol) i noticed that when ordering them the catalog online says it will fit 03-up seirra, yukon, denalli. i work here at a parts counter and im shure most of you know the denali light wont swap with the reg seirra so i had to question there design, the dude told me that it was kinda a universal set up and would work fine for my seirra. so when i got them shure enough they worked and i think there awsome and took almost no time to set them up the directions are mostly in japanese but ill send a pic if i can figure out how to work my cam.
Why will the Deanli lights not interchange?? I have seen several Sierras with Denali light in them, headlights that is.
well dude i just looked this up in the parts catalog and looks like the denali lamps will fit just not without changing the grill as well. now you might have been seeing seirra denali pickups or i belive also the old seirra c3 also had that set up but you will notice the old style denali front end facia, lamps, pk lamps, girlle, ect.. i read in a magazine somewhere that you couldnt change those lamps because the fenders on the denali are differnt then on the reg seirra but just to set everone straight there the same 88944417 for the Lh side and 88944418 for the rh side thats 99-06 so far as per the newest update. and the hoods stayed the same too. so sorry i dont know where i found the info on them not fitting but my bad..
and as for the makers of those lamps i got mine through matrix
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
